Holding Tank
Holding Tank
What is the best place to purchase or have made a new holding tank for my tri-cabin? It is 30Lx22Wx14H should be about 40 gallons. I want one that uses a dip tube from the top for clean vacuum.
Re: Holding Tank
I have had good luck with Ardemco. They will put the fittings where you want them. You should think about putting in 2 vents while you are having a new tank put in. I like 2 1" to 1 1/2" vents, one going to each side of the boat. It will get more oxygen into the tank and help control the anerobic smells.
Trojan has been sold
Au Gres, Michigan
Au Gres, Michigan
- WayWeGo
Re: Holding Tank
Ronco Plastics (http://www.ronco-plastics.net/)
Re: Holding Tank
Using Ronco Plastics cost is around 250 with shipping incl.
- P-Dogg
Re: Holding Tank
If it comes via truck freight, inspect it very very carefully before signing for it. Unwrap it, use a flash light, look at the bottom -- everything. Can you tell I've had experience in this matter?
Re: Holding Tank
well ya I check everything. it will come ups, truck yes but not heavy freight.
