TV ANTENNA
Lou
TV ANTENNA
Post by Lou »
What kind of TV antenna do you have, where is yours mounted and what are the pro's and con's?
I have the SeaWatch 2030 mounted just forward of the fly bridge and cannot seem to get one channel. Found out I have no power supply installed. So I installed a booster to no avail. Very possible the two metal buildings next to me are affecting my signal. Previous marina I got a lot of channels.
If I am in need of new antenna setup, I'd like to see what others have as comparison.
1972 - Trojan F31
1981 - Grady White Sailfish 25
1988 - Wellcraft 2800 Express
1966 - Chris Craft 36'
Re: TV ANTENNA
Glomex
Re: TV ANTENNA
Big D wrote:Glomex
X2 on the Glomex , I get a lot of channels with mine . With that said the SeaWatch 2030 should work ok in our area . But it needs a power supply to work . Also your is your TV Digital HDTV not a old analog TV ?
Re: TV ANTENNA
Post by Paul »
prowlersfish wrote:
Big D wrote:Glomex
X3 on the Glomex, great reception.
K4282
Re: TV ANTENNA
Post by K4282 »
yall are fancy, I have two 32in HDTVs and ebay HD antennas, I get about 30 stations most places IE coves, the bay, off shore it doesnt work well, I think I got 2 stations at Block Island but their less than $20 and on the island theirs so much to do I dont miss the TV, my phone (most every phone now) makes a wifi hotspot, I can also stream any movie and show at anytime with that
Re: TV ANTENNA
Post by larryeddington »
Just a thought, if you use Dish at home you can use there Tailgater antenna. It will track the satellite a bring all of the Dish Channels. I cost you around 7 to 8 dollars a month to use it as an add on to your home Dish. You will need to purchase the device which is around $350. I is a sealed tracking device which works like the $$$$$$ one the really big boys use. I have not tried it on a boat but looked at one which seemed reasonably sealed. Have not explored this yet but am thinking of mounting on radar arch when I enstall. :D
Lou
Re: TV ANTENNA
Post by Lou »
prowlersfish wrote:
Big D wrote:Glomex
My tv is digital tv. Have considered getting a new one to fit my application. But it all worked fine at previous marina.
1972 - Trojan F31
jhalb
Re: TV ANTENNA
Post by jhalb »
I would start at the cable if it is prewired. To test take a cable direct from the antenna to your power supply or tv. I had an A/b box that went bad effecting my signal. Your antenna might be good.
John
"PELICAN"
1983 10 Meter Express
