Boat 35' 1989
Simpson-Lawrence
Horizon 600 series
Has anyone had any experience with this windlass
I would welcome guidance
Thank you
Windlass not working
- Hiya Autumn
Re: Windlass not working
Could be many things , I believe Trojan use Good for the windlass option in 89. So your may have been added later . What model Trojan ? You said 35' is it a 10.9 meter? 10 or 11 meter or even a F36 ? I have to ask as there is no 35' Trojan per say , but have seen many models called many lengths (brokers get it way off a lot )
Is it doing anything ? Any power to it ? if not look a breakers , switch , relay(s) wiring .
I see you posted it maybe a f361 ? There is several F36 s (35.9')
A photo would help but here is some ID info the numbers XXX will be the last 3 on the transom ID #
F 36 TRI CABIN MODEL 360, 363, 440
F 36 SPORT FISHMAN MODEL 461
F 36 CONVERTIBLE SEDAN MODEL 460
