Interesting article on 10 meter diesel repower
Not sure if anyone has posted a link to this before, found a pretty interesting article on repowering a 10meter with 4 Cylinder Yanmar Diesels.
http://www.boattest.com/Resources/view_ ... ewsID=3361
Re: Interesting article on 10 meter diesel repower
Matt , I have seen that before .Interesting But I can tell you their performance numbers are hog wash . a 170hp would not come close to those numbers . You can't take out 330 hp engines and and replace them with 170hp (4LH DTE (170-hp) and expect to get close to the same speed . With those engines the boat would be under powered . You have cut the HP in half.
RWS repowered with 315 hp yanmars and I will bet his numbers are only slightly better ,.
My F36 came with 330 hp gassers and is repowered with 300 hp Diesels . I can tell you its slower at top end , after all its 60 less hp total . Yes cruse is faster as you can run closer to the top . I would thing it would be the same with RWS's boat .
I would like to here what he has to say .
Last edited by prowlersfish on Thu Jan 31, 2013 10:49 pm, edited 2 times in total.
Heres another 10 meter repower diesel to diesel .
http://www.sbmar.com/repowers/bossea_-_ ... l_10_meter
I can't comment on the smaller diesels, but here is the performance chart for my 6 cylinders (if I can figure out how to post it correctly)
o.k.
so I need some remedial Forum "special help"
put me in with the dumb kids, O.K. ?
Let me try
I notice you numbers are close to the same 170 hp ( speed vs rpm) I thats why I don't believe there Numbers , I also ran them on Boatdiesels calc. before there a pipe dream .
- RWS Yanmar Chart 2.jpg (32.65 KiB) Viewed 4199 times
Hi Paul,
That's what I thought. I agree with you that it seems that it would be underpowered. If it were mine I would have gone with the same engines as RWS. I wonder where that boat is now? Thanks for the other article, looks like they did a nice job. I always liked the 10 meter and think it's worthy of a gas to diesel repower.
RWS,
Thanks for sharing your numbers
Matt
RWS,
Matt
Matt , I don't belive this repower was ever done . No photos all specs on paper reread it all .
for example
"We think that twin Yanmar 4BY-180 180-hp diesels are an ideal choice for a Trojan 10 Meter repower project. One could put larger diesels in the boat, but speed was never this vessel’s strong suit. And, after all, this boat is a vintage craft being repowered, so it is wise to keep costs low. We would play to the boat’s strengths – good seakeeping stability, room and comfort. The small diesels give her respectable speed and tremendous range for cruising or fishing.
""we think" ?????
for example
""we think" ?????
Hi Paul,
Maybe you're right, I thought I read in the article that Mack Boring Co. did a repower on a 10 meter previously, and they had tested it before and after the repower. Won't be the first time I'm wrong
I would be curious to see how it would have fared after several years of use. Those little guys would definitely be working hard!
