Small Fiberglass Job
gitchisum
Post by gitchisum »
Well, the PO had removed the ladder and done a repair job on the deck that was delaminating. So thought I would take that opportunity to resurface and have a new non skid in the cockpit.
First step, get the hatch into somewhere warm. Check!
Next step
I wonder what's under there?
This can't be good
This can't be good
So I wonder how bad this gets?
Think we will stop here
The good news is, should be solid when I'm done
88 321 Sedan 270 crusaders
2001 Seadoo Challenger 2000
97 Lowe Roughneck 17TC
Commissionpoint
Re: Small Fiberglass Job
Post by Commissionpoint »
Oh bugger. What a fun project.
I am sure once you are finished it will be great.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
willietrojan
Post by willietrojan »
Just a question
How come you did not work on it from the bottom side? then you would not have to much in the way of finish work
Spanish Fort, Al
Looking for 33 International
I was thinking the same thing When I did my F30 I fliped the deck over and did it.
Willie , I was just thinking about you . I was looking at a photo of St Mikes with you in it .
Hope all is well .
gitchisum
Post by gitchisum »
Mostly because the bottom looked better than the top!!!!
PO had made some "customization" that was coming apart at the seams. So my intent was to cut that out and reglass.
First cut :shock:
Second cut :cry:
MattSC
Post by MattSC »
It will be well worth it when you're finished. Hope you had a good season with the boat
gitchisum
Post by gitchisum »
New core, glassed up and painted.
Now wait for some spring weather to get after the rest of the problems.
hatch complete.jpg (16.43 KiB) Viewed 5736 times
Post by Paul »
Looks good. What's the hole for?
Nice work
gitchisum
Post by gitchisum »
Hole is for a deck plate. Have the sea cock for for my wash down pump under there.
It was installed by the PO and was done nicely. So I left it.
