11 Meter Generator Pics Needed
11 meter
Post by 11 meter »
Hello I am new to the board. Recently I have purchased a generator for my 1991 11 meter express. The original owner never ordered the boat with one. Anyway I'm in need of pictures anyone may have of the mounts. Im not sure if they mounted to the stringer or to the side of the Waste tank. FYI the generator is an exact replacement Onan 7 kw. Thanks
rickalan35
Re: 11 Meter Generator Pics Needed
Post by rickalan35 »
Welcome to the forum.
I can't help you since I own one of the Carver/Trojan eleven meter express units (1994) and the generator is probably mounted in a different location. But I'm sure others will get back to you. Best of luck.
Rick
11 meter
Post by 11 meter »
Thank You,
I'm really enjoying the site. It's very informative and hopefully someone comes thru.
Jimmy
Post by Jimmy »
I have an 88 11 meter express, and will try to get you some pictures tomorrow. If memory serves me correctly, mine sits in an aluminum drip pan that is bolted to the stringers right above the holding tank.
Stay tuned.
1988 Trojan 11 Meter Express
11 meter
Post by 11 meter »
Thank You
I really appreciate it.
Welcome to the site . Wish I could help but my boat is a F36 .
Post by El L Sea »
This is on my 1988 12 meter convertible. It is not the original generator, but as Jimmy said, the aluminum frame between the stringers is original. Mine sits above the holding tank.
Jimmy
Post by Jimmy »
Sorry, had to leave town, ill be at the boat again tomorrow and will get you some detailed photos.
Jimmy
Post by Jimmy »
As suspected, the aluminum pan the genset sits on is mounted to the stringers. See photos. Hope this helps
Jimmy
Post by Jimmy »
The picture farther back. Sorry about the dark picture. Light off too dark, light on too much glare. I get get another one tomorrow if needed
11 meter
Post by 11 meter »
That should help. If you think of it I could use more but I think I get what they did.
Post by El L Sea »
Here is some more detail of the mounts:
