I was thinking of installing a new ac unit in my 79 f32. I was wondering where the best location would be to set the unit.
would under the rear dinette seat work?
thanks.
ac install
ac install
owner of a nice 1979 f-32
Re: ac install
You can put it there, but not the best location. Mine is under the forward dinette seat. The biggest problems are that the ducting takes up most of the starboard hanging locker, and I only have vents on top / front / aft side of that hanging locker, so it is really only effective at cooling the lower cabin. The cool air just doesn't really make it up to the Salon (even with fans pushing it there). Lets face it - the F32 Salon is essentially a greenhouse with all that glass. Also I lose the storage space of the drawers that would otherwise be under the forward seat.
Some others on the forum have setups with the vents in the salon, so the salon area gets cooled and the cool air falls down to the lower cabin, probably giving better coverage. I know I have seen the salon ducts in some pictures, but not sure where the AC unit sits, and how they have run the ducting. Also need to be careful about putting the AC unit in the engine compartment, as I am not sure it fully complies with the rules around being 'ignition protected'.
I had considered moving mine to the area under the lower station (where my water heater is now), but decided that with the amount of moisture generated with the condensation from the AC, I didn't really want that near my main electrical panel!
- Stripermann2
Re: ac install
My 16K unit is under my rear settee seat. I have it running to a main register in the salon, the sette wall and into the starboard vbirth wall. The ducting runs through the upper most corner of the starboard hanging closet so it hardly affects any storage.
You do lose the drawers on that side of the dinette. I made a grill which takes place of the drawer fronts.
System works well. However, as Captainmaniac mentioned, the salon is a green house. We have curtains to help keep salon cool.
Re: ac install
My unit is under the back deck, with blowers in the salon and anchor locker ( venting for salon and berth) My assumption is this was a factory install as documentation shows it was ordered with A/C. This is on a 1988
88 321 Sedan 270 crusaders
2001 Seadoo Challenger 2000
97 Lowe Roughneck 17TC
- Stripermann2
Re: ac install
Yep, you have the split system. The self contained units take up some real-estate.
Re: ac install
ive toyed with the idea of putting AC in my F32, however i doubt id ever use it. 2 friends who dont often leave the marina have put stand up units in their salons maybe thats an option instead? My friend has a Silverton 37, he removed his AC unit for lack of use and wanted the space, the factory had it installed under the rear deck. Myself and one of my friends decided on making covers out of sunbrella to snap on from the outside, protecting the paint and clean windows and improving the look of our F32s but mainly to shade the sun for heat, as you say greenhouse effect and for sleeping in. We also all have covers over our hatches.
Re: ac install
Come on to tennessee in the summer when it's mid 90's plus for over 100 days this summer and mid 80's at ni gh t and humidity in the 70's and try getting by without ac. This is the first weekend we will be Able to get a decent nights sleep with no ac. Fall is finally getting close.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
Re: ac install
AC is a must for us. in fact I am adding a 3rd AC for a total of 30,500 btu
