1970 CHRYSLER 318 V8 ENGINE - LONG or SHORT Block
shanachie2002
Post by shanachie2002 »
How can you tell whether an engine is a long or short block?
Neil Wilson
Do you mean big block and small block? A small block Chrysler, such as the 318, 360 will have the distributor in the rear of the engine.
A big block such as a 440, will have the distributor in the front.
shanachie2002
Since my Chrysler 318 has the distributor located at the rear of the engine, I guess I have a short (small) block engine. Thanks for your help.
Neil Wilson
raymond workman
Post by raymond workman »
The term short block means block only no heads on motor and when they say long block the mean a motor with heads on it thats shop talk and now a smale block is smaller than a big block and puts out less horse power And big block is bigger and puts out more horse power now if they ask you if you want to buy a 318 short block that means it has no heads block only with crank,rods,pistons and thats it hope this is helpfull.
shanachie2002
Thanks to all concerned for their input on this subject.
Neil Wilson
shanachie2002
Neil Wilson
a 318 is a small block not short or long so to speak Raymond post covers it well . now I will add to this there are 2 318 engines old and new type I put this info in a forum a few weeks ago I will copy and paste it below I have seen the old style used as late as 1970 ( possable Later )
they made 2 different 318s the first one was made in the late 50s to the mid 60s then when to the new style 318
I think the marine engines changed in 1967-70 or so .
did a liltle checking A engine 318 1957-67 ( old type)
LA engine 318 1967-2001 new type
these were the years the engines were made. may have use the left over A engine for later year marine engines .
the easiest way to tell is by the heads"
_________________
if you post ( or email) a photo of the engines I can tell you what you have .
shanachie2002
The Chrysler engine numbers are LM318 BWL 10-380 E054781 and
LM318 BWR 10-E056029.
While I have photos of the engines, it's not possible upload them to this site.
Neil Wilson
by the number ( LM ) I would think its the newer type but by the photos
I will know
