Edelbrock Carb Choke Wiring
Has anyone updated to the Edelbrock Marine Carbs? If so what was your solution for the hot wire? The Edelbrock info says don't use the coil or alternator.
The engines are Chrysler 360's
- IMG_20240715_175047020_HDR.jpg (55.58 KiB) Viewed 15611 times
- IMG_20240715_175025932_HDR.jpg (63.53 KiB) Viewed 15611 times
Re: Edelbrock Carb Choke Wiring
A lot of people have hooked it up to the + on the coil or the alt. If It was mine I would find a 12-volt ignition feed. You did not say what engine you had.
I'd rather not go to the positive coil side or the alternator. Trying to figure out an ignition feed connection.
The engines are Chrysler 360's.
- 17211662911638149634843448975824.jpg (103.65 KiB) Viewed 15579 times
12-volt power on the ballast resistor.
Thats a great idea ! I didnt think of that. Ill give it a try. Thanks
Im thinking of creating a fused relay swith to power the choke from the starter solenoid.
- relay.JPG (22.94 KiB) Viewed 15564 times
- harness.JPG (45.87 KiB) Viewed 15564 times
- choke relay.JPG (21.26 KiB) Viewed 15564 times
It does not show the solenoid wiring, But I believe the terminal you're using to activate the relay goes to the + side of the coil. Full 12 volts cranking, lower voltage running as it feeds from the coil after the ballast resistor. Will the lower voltage keep the relay on? Would the relay draw much less than the choke coil heater? I don't know but I bet it's close.
I converted my 1982 F26 318 to Edelbrock 1409 w/electrick choke. Hooked up to positive ballast resistor (top right side of ballast viewed from aft). This is a consistent 12V while key is on.
-Marko
-Marko
1982 261 "The Cruise"
Sometimes I wonder if my boat misses me to.
So I built two harnessees based on the photos I attached for the chokes and they worked great !
Thank you for the update.
