Edelbrock Carb Choke Wiring
Martino
Post by Martino »
Has anyone updated to the Edelbrock Marine Carbs? If so what was your solution for the hot wire? The Edelbrock info says don't use the coil or alternator.
The engines are Chrysler 360's
Re: Edelbrock Carb Choke Wiring
A lot of people have hooked it up to the + on the coil or the alt. If It was mine I would find a 12-volt ignition feed. You did not say what engine you had.
Martino
Post by Martino »
I'd rather not go to the positive coil side or the alternator. Trying to figure out an ignition feed connection.
The engines are Chrysler 360's.
12-volt power on the ballast resistor.
Martino
Post by Martino »
prowlersfish wrote: Wed Jul 17, 2024 8:23 am 12-volt power on the ballast resistor.
Thats a great idea ! I didnt think of that. Ill give it a try. Thanks
Martino
Post by Martino »
Im thinking of creating a fused relay swith to power the choke from the starter solenoid.
choke relay.JPG (21.26 KiB) Viewed 15563 times
It does not show the solenoid wiring, But I believe the terminal you're using to activate the relay goes to the + side of the coil. Full 12 volts cranking, lower voltage running as it feeds from the coil after the ballast resistor. Will the lower voltage keep the relay on? Would the relay draw much less than the choke coil heater? I don't know but I bet it's close.
Marko
Post by Marko »
I converted my 1982 F26 318 to Edelbrock 1409 w/electrick choke. Hooked up to positive ballast resistor (top right side of ballast viewed from aft). This is a consistent 12V while key is on.
-Marko
1982 261 "The Cruise"
Sometimes I wonder if my boat misses me to.
Martino
Post by Martino »
So I built two harnessees based on the photos I attached for the chokes and they worked great !
Thank you for the update.
