The Trojan Rudder Port
Exploded View
Rudder Port Details
The packing nut should be tightened only enough to stop water leakage, and then locked securely with the lock nut to prevent its loosening. If repacking becomes necessary, use only flax packing. Use of graphite packing may cause corrosion in salt water.
typical trojan rudder port
